My hot water has suddenly stopped working. The heating works as usual but the boiler does not ignite if i turn on the hot water. Up until now I have been able to run the hot water independently of the heating with no problems simply using the control panel
There is no no fault code coming up, the pressure in the boiler is fine - just no response at all. I have tried turning off and on again and when I press the i button is shows S.30
I have had my plumber visit very recently to look at an issue with noise early in the mornings coming from the 'mega-flow' system in my loft. This noise only occurs early in the mornings when showering and he changed the pressure reducing valve. The hot water has been fine for several days since then. Maybe the x2 issues are unrelated. For what it's worth the noise has not gone away!
Any ideas would be great.
Thanks.
Thanks.
