Hi all,
Wondering if I could get some help or advice on my problem...
So the setup is as follows:
Vaillant 624e ThermoCompact Boiler
InDirect Coil Hot Water Cylinder in loft
Stuart Turner Monsoon Shower Pump serving shower
Hive V2 Thermostat
Everything has been working fine 'til British Gas came to do a service. Since then there is either no or very luke warm hot water when the hot water is turned on. Heating works perfectly fine. It is also important to note that the hot water pressure is low.
British Gas came out again and checked and said that the thermostat on the hot water cylinder was clicking at 30 degrees and despite the boiler saying 60 degrees when heating, the thermometer only shows approx 35 degrees from tap. So the hot water cylinder was replaced and now clicks to 63 degrees. The boiler works fine but there is still lack of hot water pressure and hot water.
There are no leaks and it seems that the boiler is heating up fine and is holding pressure.
Anyone have any ideas on what could possibly be wrong?
Hive V2 Thermostat
