Our boiler keeps tripping out every now and again and needs resetting.
Its recently been serviced by a engineer and I have also stripped it down and given it a good clean and hoover out (burner,HE,fan etc..) but it is still doing it. It also had a small leak on the joint of the pipe that feeds into the HE but I have fixed that as well. I think that it mainly happens when the CH is on.
I asked the engineer about it and he said that it was because the heating was set to max temp and to turn it down a little bit, did this but it still tripped out
What is the best way to find out what is causing the fault?
