Hi All,
Just been browsing this forum seeing if I can get anything related to my boiler problem, have not found anything so asking if any of you can help or advise me...
My boiler failed on Thursday night at around 1AM, it was working perfectly at 8PM (approx) however when the heating turned off (from timer) it never came back on and hot water did not work either.
I went down and noticed the boiler was powered down and totally dead.
The next day I checked the mains and everything seemed OK, after some more research I found out there are two fuses on the PCB.
One fuse (1.5A on the right) was blown, so I replaced this with a spare on the cover however I fired the boiler back up and the boiler was on for approx 5 secs, then the fuse blew again...
upon power-on the boiler made a brrr brrrr brrr noise (best I can describe it...) then a click occured (similar to a relay/switch) and the boiler died...
I replaced the fuse and the same happend again...
I am at a loss what to do next.... Any tips or help would be very appreciated...
Just to let you know I have opened the silver screw on the pump and it seems to be rotating OK and it was also dribbling water OK.
I am otherwise looking to call out British Gas for a fixed price repair on Monday... (just wondering if its simple/diy) F.P. Repair is £205..
Thank you all for reading..
