Hi
I have a valiant 242/1 boiler , less than 5 years old. My issues is that when i turn the hot water tap on i get hot water instantly but when i turn it off an immediatley turn it on again i find that i only get cold water. i have to then shut the tap off and wait sometime 10 mins before turning the tap on and the hot water light on the boiler comes back on. i had a look at the microswitch the other day when this happened and i noticed that the actuating lever was going down onto the microswitch but doesn't look like it was depressing it far enough. when i depress the lever above the microswitch manually by an additional millimeter the hot water comes back on. Please note that the microswitch /Diaphram were recently replaced by a plumber when DHW stopped completley. do you think he has has not put the lever in the correct position properly ?
The other thing i only noticed that the water pressue which should be 1.5 , i've recently every couple of days have had to top it off. Something i never needed to do before the plumber came in and stripped the boiler to find the issue and then fitted in the microswitch + diaghpram. Not sure why this is the case now ? any ideas?
