venturi shower
16 Sep 2005
Birmingham
Does anty one know if you have to use the manufacturers shower head in conjunction with venturi showers. I want to install a Trevi boost but I want to use a flush mounted ceiling shower head from Aqualisa.
Will this work OK??
MOD
split as the post was 3 months old
Probably just down to flow rates. The head will need a certain volume to "fill" it.
One of my workmates had a prob with the boost. Stripped cleaned, water where it's supposed to be but wouldn't pull the hot. Turns out the rubber rose in the head was the fault, once it was renewed shower worked fine. Please don't ask why as we cann't figure it either.
A venturi shower will not work properly if the resistance of the outlet fittings (hose and head) exceed the design level. The operating principle is that the cold water passing through a venturi tube creates a suction effect which draws the hot water into the mixing valve.
