We have inherited a Veritas alarm, installed about 5 years ago.
The master control box has it's own feed off of the electrical CU in the house which is switched on.
When we moved in, I believe that the Unset LED on the keypad was constantly lit. Since doing some work on the electrics in my loft, I have noticed that the LED isn't constantly lit.
The keypad backlights are on when I open the flap, and I am able to set and unset the system ok. The LED itself works because it appears when I unset the system (but then goes off)
2 questions:
Should the unset LED be on constantly (when unset)? or was I imagining things.
Does it actually need it's own power supply- if not then I doubt the wire I disconnected is related to this. (I have reconnected the wire but still no LED)
TIA
Paul
2 questions:
TIA
Paul
