- Joined
- 6 Aug 2023
- Messages
- 2
- Reaction score
- 0
- Country
Hello, Just wondering if anyone can help please. I've just been wallpapering the hallway where the keypad for the Veritas 8 security Alarms system is. I turned of the mains power and removed the Keypad box from the wall. Papered and replaced the unit. I've come back to rewire and there's no power on the pad. (No green lights). I'm guessing I've blown the fuse??.... there appears to be no power/voltage across to the Red and black cables? Would I need to open the main Alarm box and check / Swap out the Keypad fuse?... IR sensors are working and green light on the Main Alarm box. My concern is if I turn off the mains and open the Alarm box cover would it still set the Alarm off because of the back up battery and tamper switch trigger? With the keypad not working I wouldn't be able to stop it so unsure best steps. If it's a swap over of the 500mA fuse then hopefully it would bring the keypad back to life but if it isn't wouldn't the Alarm just keep going off without a way to stop it?
