Veritas R8Plus changing preset codes
19 Jul 2011
hi we have had a Veritas R8Plus alarm install which is great but it has been left with the standard 4321 codes.i would like to get rid of all these codes and just have the same code for the users and master.
i know i can assign uses and code but how do i change the pre-set master code then the other pre-set users codes.
reading the manual is like swimming in chocolate. great to do but you don't get any-ware fast.
cheers
jon
Please point out the difficult bit, I'm having trouble finding it.
To Change Code
Enter Existing Code
Press Prog
Press 60
Enter New Code
Press Prog
Press Reset
many thanks for that when i do this will it change the master codes and then just go in and setup additional users.
cheers
jon
Just the code your changing.
Then use the master code to add or delete the others.
You WILL not be able to have all the same, each has to be different.
