Hello - can someone please advise?
I have a leak at one upper corner of small dormer window (very easy access). Window is about 3 feet by 2 feet, if that big
Repairs proposed suggest (in as few words as I can)
remove tiles and existing covering,
check condition of decking (what's that?).
provide any new decking required at extra cost
Lay 1 layer glass fibre 3B and 1 layer polyester HP180, bonded with hot bitumen
Form new drip edges, upstands and cap layer in HP 250 roofing felt
I'd like to keep the appearance as it is -- is there a solution that uses the old-fashioned approach, at least for the final layer - lead I think, maybe some zinc? Does it still need the other materials underneath in that case? What is usual for this sort of repair, in keeping with the house (it's a modest arts and crafts house with almost everything original).
Unless the decking is really rotten I'd probably rather treat it / patch it than replace it - you hardly see wood today as good as what is generally used in the house (1908 solid middle class stuff...) . Is that bonkers?
any advice would be much appreciated.
The above work was quoted at 800 pounds plus vat, which seems a little steep to me (no scaffolding, remember) ... I'm now looking for specialist lead roofers which I guess will cost even more....
thanks in advance!
thanks in advance!
