Thats interesting. I thought the viessmann tubes were made by Thermomax! The Vaillaint tubes were schott and they had a recall around 2-3 years ago, so I'm surprised on two counts with this news.
I have only fitted the 300's so wonder if those are ok!?
If the V300T uses boiling alcohol then they have to be mounted vertically with the collection manifold at the top.
If the 200T has fluid transfer and connections at one end only then doesn't it have to be mounted with the connections at the bottom on a drain back system to ensure all the fluid drains out?
I was not aware that there were still direct fluid pipes being sold.
My memory is that Viessmann showed us a solid copper tube there.
Trouble is these manufacturers seem to change their suppliers/designs so often!
