Hi all,
I have Vogue C40 boiler that is around 9 years old.
Sadly lacking in regular servicing !!!
Recently it has been running the CH water temp too high.
We normally have the CH water temp set to 60deg, but in the last couple weeks, it has been heating to 70+ (despite the stat being set at 60) and, therefore increasing the pressure, sometime beyond 3 bar.
The cold pressure is normally at 1 bar, and goes up to 2 ish when the temp gets to 60, but with the temp going above 70 and the pressure beyond 3 bar, it's dumping water through the relief valve and then when cools down the pressure often drops below minimum, resulting in a top being needed.
I've just done a system flush (using a Norstrom Proflush), but this doesn't seem to have helped. Will be reflushing this evening and refillint with inhibitor tomorrow)
I'm suspecting the flow thermistor at the moment because of the temperator overshoot from what it's set to. I've just tried with the CH water temp set to 50 deg and it still went up to over 70.
I also think the system needs a bigger expansion vessel, which I'll be looking into getting fitted very soon.
Any ideas, thoughts etc. greatfully recieved.
TIA.
TIA.
