vokera boiler 03 error
  • Thread starter Thread starter llewop
  • Start date Start date
L
llewop
My vokera linear boiler constantly errors off with o3 error. The boiler seems to work ok. Can anyone tell me how I can fix this problem. 03 error is fan/flue problem so the book says.
You could start with checking to see if the fan is working and that the flue isnt blocked. Is the fan noisy or does it just buzz or not even move?
If the fan is working and the flue is clear then without looking in the book you could have a problem with the air pressure switch not sensing that the fan is working
Have not checked the fan but have not noticed any noise. The boiler errors off then restarts its self. No problems with heating or hot water. You may be correct with the air pressure switch I will check it out in the morning after work. Thanks for the help I will let you know how it goes.
checked boiler fan as thought it turns ok no noise. Where is the air pressure switch in location to the fan.
