Vokera Compact 28 continually firing
2 Apr 2009
I have what is essentially a Vokera Compact 28 boiler which has developed a problem. Initially there was no hot water at all and I checked the secondary thermistor, which was goosed. After I changed this though the boiler is continually firing, even when there is no call for it. Any ideas?
Regards,
<<gordy>>
no my friend
what you have is a sabre compact :D
open your wheelie bin and lob it in. :lol:
what pipes are getting hot when it fires??
what is the led doing?
I am only guessing but can only imagine that you have put in the wrong value of thermistor and its providing heat because it thinks its protecting the boiler from a frost threat!
What exactly does a "goosed" thermistor look like or measure?
Yes and yes, it's been an endless stream of issues.
The original thermistor was eroded at the tip to the extent that water was leaking though the thermistor and out through the wiring. The part was changed with part no. Vokera 8484 as per expanded diagrams. The LED is green and as for the pipes, will update that later, she has had the heating and water on this afternoon, so they all are :)
<<gordy>>
