vokera compact 28
23 Dec 2020
Hi Guys new to this but looking for some advice.
I have a vokera compact 28 boiler. Just recently it has started constantly cycling on and off. It fires up runs a few minutes then cuts off. The DHW seems to run ok but the CH doesn`t it just warms the radiators and no more. The fan and the pump are new. I have noticed that the second pipe from the left underneath the boiler gets really hot when it fires up then when it cuts off the pump still runs and the pipe becomes cold. once its cold the boiler fires up again. I think its overheating. I am just looking for some guidance what the problem might be. Dont want to spend a lot as i know its an older boiler. Just wondering if its something that can be repaired. If I have an idea what problem is can work out if its worth getting a plumber in to repair or buy new.
Hi Chris_W got to be honest no service but had fan and pump replaced.
So if he issue was beforehand, pump replaced, still same issue, how come you haven’t called the engineer who fitted the Pump? It might be a flow/return issue with a valve not being open fully, such as a magnetic filter. If it’s boiler related best advice would be @ianmcd or @vulcancontinental, although they won’t be able to offer gas related advice.
ok thanks it was a plumber fitted but he also doesn`t do gas.
Hi Ianmcd, I replaced hoses a couple of years ago as they were leaking. But I'll take them off tomorrow and give them a clean. I'll let you know how it goes. Thanks
Hi ianmcd, just to say took off hoses and cleaned they weren't bad. Put in cleaner says to run for an hour or leave for a week. As mine hasn't been serviced I'll leave in a day then flush out and put more cleaner in. If that works after a day or two I'll flush out then add inhibitor.
post a pic of your boiler, vokera called lots of different models compacts, just so we know we are thinking the same model
