Hi I moved into a flat about 2 months ago with the above boiler and it has just started causing me a few problems. The other night the boiler started firing (as if demand for hot water) and kept doing so every 30 seconds. Also if any of the hot taps are used all the radiators seem to get hot suppose this could just be some kind of heat dump though. Had a play around with the controls on the radiators and the water/ch temperature control on the boiler and seems to have stopped the random firing.
Also noticed a funny noise sometimes when the boiler is cutting out. Strange to describe but almost like a short circuiting noise.
Fan seems to be running ok. That's about as far as my knowledge can get me with describing the problem any ideas would be appreciated.
Cheers
Jon
Cheers
Jon
