Vokera Excell 80 SP
2 Sep 2009
Lanarkshire
I am looking for a bit of advice on the combi boiler above. It was making a strange noise when it was fired (a loud humming). It has now stopped working all together.
The pilot is lit and there is power getting to the boiler but it never fires. The pressure is frequently dropping and although I can top it back up, it still does not fire.
I have previously replaced the control box (not sure if it is actually called something else) and the diaphragm. When there was a problem with the diaphragm, I was able to diagnose by pulling the arm out to get the boiler to fire. This no longer works.
Any help or advice would be greatly appreciated. If any more info is needed, please let me know.
It sounds as if the fan is jammed.
However, inspecting inside the combustion chamber and working on these parts should be by a competent gas registered engineer.
Tony
Fletcher, where in Lanarkshire are you?
Faulty item can be changed but it would be better to service the boiler during which the faulty item will be replaced.
Difference is either carry out repair and get the boiler working for it to subsequently fail again due to lack of service. This could end up in subsequent calls as and when the boiler fails again. Better option is a service as prescribed by the makers and replacement of faulty or worn components- this restores the boiler to near factory spec.
Carry most common components to endeavor first call fix
