Hi, got a really annoying problem that hopefully has a simple solution.
I've got a Vokera Excell 80SP, no idea of age, it came with the house
We have excellent water pressure and the boiler is on the same level as all the plumbing.
When turning on the shower, or any other hot tap the boiler will fire up, sometimes after a good minute or so delay and hotwater will run unfortunately after a further minute or less the water will run cold for a minute or so (ice cold as if straight from the cold tap) and then eventually the water will run hot again, this yo-yo'ing is reasonably consistent, although on other ocassion i can run the shower with just the hot tap fully open and with the dhw temp at max and get constant hotwater (although this is almost to hot to bare).
I'm leaning toward the thermistor.... but hey i'm no expert...
Almost forgot, the problem gets worse if we try to use the cold tap to reduce the temperature (runs hot cold more often)
