Vokera Excell SP80 Dripping overflow
21 Dec 2006
Newcastle upon Tyne
I'm after a bit of advice folks......
For the last few weeks the pressure has been dropping on my Vokera combi. It is now dropping by almost 1 bar a day.
I took up several floorboards and couldn't find any leaks but I read some posts on here about the 15mm overflow pipe dripping - and sure enough it was.
I let approx 4 litres out of the system and tried to repressurize the expansion vessel and the dripping stopped. Excited about by newly found skills I opened a beer to celebrate but I've just been and checked the pressure (2 hours later) and it's dropped again and the dripping has started :oops:
Does this mean that the expansion vessel is damaged or could there be another problem?
secondly to my learned monkey hanging pal,
try isolating boiler and releasing all the c/h,then re pressurise to 1 bar
while the front cover is off check operation of dhw micro and pump proving micro.
if any of these are slow to return, it will keep boiler firing when no demand
possibly causing it to over pressurise
oh and change the PRV
Thanks for the replies - I'm a complete novice and had no idea what an expansion vessel looked like 2 days ago. This all sounds very tricky/complicated and I might need a chap wearing Vokera overall's to come and sort this out.
I'll keep you posted...
Thank you.
missed this
system or boiler should be empty and open to atmosphere when you recharge ex v
i have the mi's if you e mail me adress in profile
of stick an addy in yours :idea:
Hi kevplumb,
Apologies - I'm away from my desktop and don't have frequent access to the net at the moment. E-mail addy completed in profile now.
Will completely drain system and try to recharge to the EV as per your advice.
D
kevplumb,
Got them - many thanks for the help :D
The boiler is more than 12 years old now but in its quite reliable life its only had fitted: 1 x replacement fan, a PCB (which I was never sure about!) and a couple of diaphragms. If the EV needs replacing is it worth doing given its age or should I consider a new condensing boiler? Any thoughts welcome
If a Vokera two generation older than your Excel is still chugging away reliably, I fail to see any reason to replace it. Of course, a service as mentioned in the book is mandatory for reliable operation.
I dont see that you have yet repressurised it according to the requirements.
The FAQ on this site gives full instructions. As stated above it needs to be pressurised to 0.9 Bar with the system open to atmosphere.
While you do that if it is seriously failed it will not pressurise at all !
If it does then repressurise the system to about 1.5 Bar and turn on heating and watch the pressure gauge, it should not go about about 1.8 Bar.
If the EXV can be repressurised Ok then the PRV may still drip a little but they often stop after a few days. If not its fairly easy to replace.
Those are getting a bit old but they are still quite reliable and it could give you another few years service. They are still totally repairable and spares are available.
Tony
kevplumb,
Cheers - will consider that as an option.....
DP,
It has been reliable and to be honest, if the boiler hadn't been fitted where it was (cupboard in the back bedroom) - I would never have bothered replacing the noisy fan
Agile,
You're right - I haven't re-charged it as per the instructions but now I'm home from a few days away I'll do the job properly this time :wink:
