1) BOILER TYPE: VOKERA
2) MODEL: LINEA 28
3) LAST SERVICED: OCT 2007
4) LAST SERVICE APPEARS TO HAVE AFFECTED THE OPERATION OF THE BOILER.
5) The problem with my boiler is that when the C/H temperature control is at its' maximum setting, the primary water produced by the boiler is 58 DegC and should be around 85 DegC as per the boiler specification. The temperature of the radiators is too low to heat the rooms of my house sufficiently. In October 2007 my boiler was checked and the thermistor on the domestic hot water heat exchanger was changed. The boiler hasn't really been used again for heating until October of 2008 and it is clearly not working as it should. There is a high temperature trip on the primary water circuit but perhaps someone has a similar experience with my problem and can offer some advice.
The man that repaired my boiler was a "part changing expert" and the job was done whilst I was away and my house was rented out. He ran up a considerable bill whilst he changed parts to get the boiler to work again.
Regards
Dyson
2) MODEL: LINEA 28
Regards
Dyson
