Vokera Linea 28 combi boiler
5 Aug 2006
OK,
I have the Vokera Linea 28 combi boiler. This supplies my hot water as when required, and also the radiators.
Each radiator has a knob at the bottom, with numbers ranging frm 1-5, 1 being cooler, 5 being hot.
However, there is no thermostat as such. Yes I could set all the radiators to 4, but I want to be abe to specify a temp and the boiler come on and off when it cools/heat.
The only digital thing the boiler has at the moment is a 7day programmable timer, which does a good job and is easy to use.
Is there a thermostat which can be retrofitted to this boiler. I would get a electrician/gas fitter? to install the boiler side of things. I would prefer wireless, with maybe a remote so i can override things from my bed.
Any ideas???
Don't know about a remote, but any wireless stat can be fitted to your boiler.
A heating engineer would be the logical choice, but can't see why a good sparks couldn't do it.
Many of the later wireless stats have a remote which fits into a holder or can be handheld.
However, unless you get up at widely differing times like me then its a little pointless.
You should have a room stat under the energy efficiency regulations and it will save about 4% on your gas bill.
