Hi. My boiler has an intermittent problem. Sometimes it will not start and when it does it sometimes switches itself off after a couple of hours. When the problem arises the boiler will hum but the pump and the fan will not kick in. The boiler is also losing pressure and the pressure rises significantly when running. However the boiler will cut out/not start even when the pressure is above 1 bar. From reading previous posts it appears that this may be a pressure vessel problem. If so would this account for the boiler not working when the pressure is sufficient. I have checked for leaks and all pipes appear to be dry. The problem is occuring on a daily basis but I cannot get anyone to come and look until well after christmas. Any advice would be gratefully received.
