hi everyone,
The boiler is a vokera option boiler and the problem i'm having is that the red fault light keeps flashing, the boiler works but when I call for hot water or turn on the central heating the boiler fires up for around 10-15 seconds then the boiler shuts down and the red fault light flashes for several seconds, the fault light then turns off the green light on the control knob lights up and the boiler fires again for around 10-15 seconds and then the red fault light flashes again and this repeats.
I'm with British Gas and I have a Homecare policy with them but so far I've had 3 engineer visits and the problem is still not fixed, the second engineer replaced the PCB which has made no difference at all.
can anyone shed light on my possible problem please as the last BG engineer has said he hasn't got a clue whats at fault.
Thank you.
Thank you.
