my central heating system doesnt start up when you switch it on the fan and pump trys as the pressure drops a couple of bars and i have stripped the pump out and its not siezed,but there is a buzzing noise from the board as well and when you turn the system off the bars return to 1,5.the pressures fine the pump seems fine do you think its the pcb board or something else i can check any ideas thanks gritman
