VW camper van roof insulation
19 Nov 2008
Dorset
My niece has a VW campervan, that has a lined roof. 1/8inch plywood, with a 1inch gap, but it feels hot in the sun.
I suggested filling in with expanding foam, but as I will be doing it, am a bit worried about blowing the lining off the roof.
Has anyone done this before and can give me some guidance please?
C
I would be removing the plywood and insulating behind it. Wall panels should be the same...
Hi J and K,
I'll have very little time, so no work involved, just expanding foam. What would be the best way?
I think that as one end it open (by accident) I'll drill holes at the sealed end and let it creep down the van.
Thanks for both suggestions though.
C
Hi J and K,
C
Can't see that happening myself. It's going to clog up....
Most installs use the white insulation on a roll similar to stuff used in your attic, it's not itchy stuff!
Hi B,
Yes, when I did a conversion, I insulated before fitting panels, but this has to happen between quick visits to my niece, so it's foam or nothing
Thanks, C
