wall paper on just one wall
12 Oct 2007
Hi all, just finishing off the dining room. I am papering just one wall. I am assuming the two corners are not going to be perfectly straight. Am I correct in thinking that the best way to overcome this is to overlap the paper by a couple of inches in the corners and trim the excess of. Thanks in advance, Simon.
Strike a center line down the middle of the wall and either go either side of the line with the paper or place the first length over the line and work outwards. You can check if the pattern will be equal at either side then.
