wallboard adhesive
23 Dec 2007
Yorkshire
hi, i'm aiming to insulate a bedroom wall, using knauf plasterboard laminate which is backed with polystyrene, by bonding it direct to the existing plastered wall. will it stick ok with ordinary plasterboard adhesive? if not what do i use please? should add that i don't want to lathe it as room is small enough already. many thanks
What sort of wall is it (solid/cavity) & whats already on it :?: Have you checked the manufacturers specc sheet/guide; it's always a good idea to follow them :wink:
it' a single leaf brick wall brick wall rendered and then plastered. have trawled through knauf's website but can't find any reference to bonding it except fastening to lathes.should add also that it's an exterior wall which is tiled on the outside
