Wallpapering directly onto plasterboard query
27 Jul 2006
Apologies for the revisit as i see this subject has been done a few times before, but a number of the threads appear to be very old so wanted to see if the advice had changed
So i've built some built-in wardrobes, and i have a strip of plasterboard (floor to ceiling) at each end to finish off the wall
Size is 2.4m x 0.6m
The wife wants me to wallpaper to match the rest of the room (embossed)
I've seen mention of gyproc drywall primer, lining paper, multiple counts of emulsion etc etc but am unsure IF in the future we wanted to re-wallpaper, which would tolerate scraping it off without destroying the plasterboard
I'm happy to spend a few quid if there is a roll-on equivalent of 'skim' that is thought to be worth the money
Any responses and advice gratefully received and reciprocated with a thank you ! (y)
TIA
Apply gardz.
Wallpaper is impossible to remove from plasterboard so seal first. Other sealers available
thanks @Wayners
i assume the gardz only prevents the absorption and seals the surface ?
would you lining paper on top after applying the Gardz or not bother ?
i'd got it in my head that there was a roller-on type skim alternative product kicking around that a lot were using, that would offer an additional layer and thus protect the plasterboard from any gauging
have you used anything similar to my description @Wayners and if so, what's your thoughts pls ?
The Gardz enables you to remove the wallpaper in the future. Without it, when you try to remove the wallpaper it will ruin the paper on the plasterboard.
You will be using embossed paper. No lining paper or skim will be required.
definitely don’t put standard paste or mist coat emulsion straight on bare board if you want to strip it later mate, the paper face will bond to the backing paper and pull the board apart when you steam it off. brush on a coat of zinsser gardz or beeline primer sealer first. it seals the gypsum and creates an impermeable barrier so when you eventually strip the embossed paper in a few years, it peels clean off without gouging into the plasterboard face.
