Hello
I am currently in the process of wallpapering my landing, passageway and stairway. Whilst I'm not brilliant I'm competent(ish) but I'm about to wallpaper the wall above the top of my stairs on the landing.
Now normally when you wallpaper you’re either wallpapering to the skirting or the ceiling (ie an edge of some description) that you cut into. But above the stairs the wall just stops and slopes downwards, becoming the ceiling to the stairs (if you see what I mean).
I’m worried that cutting across is going to look rubbish (especially when viewed looking up at it); especially since the paper is slightly thick and the line isn’t perfectly straight. Is there a tip to making it look good? Should I cut when the paper is still wet or would I get better results trimming when dry? Would carefully tearing the paper be better, rather than cutting, as the edge would then be more feathery? Although my heart freezes thinking about risking tearing paper freehand!
I’ll have the same problem in the passageway, as there’s a small section of wall above the front door with a lower ceiling than the rest of the passageway which will also need papered down to. And for added difficulty that is arched
