- Joined
- 5 Dec 2024
- Messages
- 2
- Reaction score
- 0
- Country
Hi.
This is my 1 st post, I'm finishing off my bathroom.
However I didn't take into account the 2 walls of shower enclosure are not square, but they are flat / plumb.
Joins are all taped up with waterproof tape, shower tray recessed into wall.
I don't want to take off the aquapanel and cement board I put up, or take the shower valve out in order to try and square them.
The issue I have is if I just plough on, the internal corner trim that comes with the wall panels is 90°, so this won't fit against the wall, so i can't use it for the wall panels.
1.Is it OK to not use the internal corner trim and just carry on with wall adhesive, apart from the corner where the trim was gonna go / wall panelling joins, I was gonna put loads of silicone, then when the next board goes on, silicone that joint as well.
2.Can't see how this is any less effective than the internal corner trim? The trim needed to have silicone in it anyway.
3.Is the only advantage of internal corner trim - tidy and doesn't go mouldy?
