hi have read all the similar posts but still unsure about this.
i have about 50m2 of parquet living dining and 10 of concrete extension.
I really really do not want to have to lift the parquet and bitumen.
I cant really lay wood over whole area as it will take level up to high
(ply + foam + board).
Other added complication is the concrete area is slightly higher (2-3mm) but is on main run from living room to extension, so not somewhere i want to put a divider bar or similar.
So 2 different questions.
a) can i for example put a thick foam underlay on the parquet with no dpm, and then a thinner foam underlay on the concrete with a dpm?
b) or can i lay a concrete screed over the parquet ?
thx......?
thx......?
