Warmaline and beyond!
15 Jun 2009
Hertfordshire
Hi All,
My Summer Project is to redecorate our place. However I am a novice at certain things so would appreciate someone's help please.
On some of the outside walls we have mould, so I want to use Warmaline. So is this right:
1. Take off old wallpaper
2. Get rid of mould
3. Put on Warmaline
4. Lining Paper
5. Paint
Questions:
1. Do I need to do anything before I put Warmaline on?
2. Are there any tricks to putting Warmaline on?
3. Generally - are there any tricks to wallpapering rooms? (Which we will then paint over).
4. Any other suggestions?
Thanks,
David
Al
You have to find out why you have the mould in the first place. Putting up waramline is not the be all and end all of this. Usually its condensation, lack of ventilation and none movement of air. This causes air to stand still usually in corners or near the ceiling due to warderobes and other obstacles. Warm air that touches a cold surface will condense and cause mould. Depends how old the house is to determine why the problem is there.
"This causes air to stand still usually in corners ... due to warderobes. Warm air that touches a cold surface will condense and cause mould."
Well that is the problem with one section - sadly we can't put the wardrobe anywhere else! So what else can we do?
Thanks.
It's unlikely you'll have a problem. The warmline is too warm for condensation to settle.
If you cant get any ventilation the area like inserting a vent or airbrick then the warmline might be the only thing you can do to warm the surface up.
