Washer Dryer No Power
25 Mar 2004
Sussex
I have a Indesit IWDC6125 washer/dryer and its just stopped working.
There is no power on the display panel at all and nothing works, no lights.
I have checked the wall socket and 13 amp fuse and both are ok.
Would the door switch cause nothing to come on?
Does the model have a fuse inside anywhere?
Any Ideas?
Do you have a multi meter, if so check for mains voltage into & out of the suppressor in the first instance.
The door being open or closed will make no difference; it just wouldn't start if it was open.
Just checked and I have 240v in and out so that rules out the Suppressor!
Trace the 2 wires from the suppressor up to the main board, if you have power there then your main board is probably faulty & it will probably not be an economic repair.
