washer dryer - soaking items at dry cycle
11 Aug 2011
my Indesit WID 126S washes fine, but when put to dry cycle to soften towels (off the line outside or whatever), then soaks everything again - and warm
This happened before - but lceared itself or may be the salts i put in helped.
presume heating element working.. help please.?!.
Make sure drain hose it up high enough then check the filter and test heater to make sure it's getting hot.
thanks, but..
just a thicko girl - how do i test the heater ? - and no filter available - i think it's a self cleanig filter (whatever that is..) - am i gona have to take off back panel or something - access is very limited
Every machine has a filter , yours is at the front bottom right hand side remove the kick strip. To test it put on empty cycle and high heat wait about 20 mins then stop it and open the door is it hot inside.
will try that- but no kick plate at the bottom of mine - which is why i think it's inside or on back panel - will try when i get home this evening-
thanks for now though
