washing machine
28 Jan 2010
Cardiff
I've got an hotpoint Aquarius WF100, whenever i put a wash on, it goes for a few seconds then stops and the on and wash enhance light flash.. Ive checked if its level by altering the feet as i just moved house..I checked the pipes etc..Cant work out whats wrong! Can someone help me please?? :roll:
Do you have the manual, in trouble shooting section it should explain the fault code.
Failing that try your post in appliances section, some clued up guys there!
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
f1 and f17 share the same light
