I've found kind of similar posts to this before, but not exactly matching my situation.
Currently into my bathroom I've got:
- 15mm mains feed in, supplying toilet, cold basin tap and through to outside tap (via non-return etc.)
- 22mm cold feed from storage tank in, supplying shower.
- 22mm hot feed from cylinder in, supplying shower and hot basin tap.
- No bath currently.
- Also coming in is radiator feed + return, giving grand total of 5 pipes entering bathroom in one place.
Plan is to fit a small bath + new shower to replace existing shower cubicle. Also replace basin.
New basin tap is mixer, new bath taps separates.
Shower is mixer, also have shower pump to fit somewhere sensible.
As I understand it, it's highly recommended to fit shower pump on dedicated supplies (inc. flange on cylinder), but the idea of adding two new 22mm pipes to the 5 existing ones kind of makes me a little crazy.
I was thinking, I could use the mains feed to supply toilet, basin as previous, and also the new bath cold tap; thus meaning the existing 22mm cold feed from storage tank could be dedicated to shower pump.
Think I'd still need a single new 22mm in for hot supply to shower pump.
Basically I think I'm saying - can I connect the bath cold tap to the mains?
Does this sound like a plan? Or does anyone have any other bright ideas how to reduce the number of feeds. I presume T-ing off for the pump is ultimately the wrong thing to do. I was wondering about pumping all of the appliances (shower H&C, bath H&C and basin H) but that seems dodgy too for some reason. Also I was worried that pumping the bath might drain the tanks too quickly.
Any advice appreciated,
Surreywill.
Surreywill.
