water in pressure switch
19 Sep 2007
Manchester
hi there
could anyone help me, friends boiler a baxi solo keeps gettin water in pressure switch tubes, could anyone one tell me how to cure it
cheers
Get a RGI in, APS is part of the gas/safety system and on some solos they are inside the sealed combustion chamber.
hi there
cheers
You seem to be trying to fix boilers for someone else.
Thats not a good idea if you are not gas registered or insured!
We cannot give advice on DIY gas work on this site.
Looking through your history Horlicks there is steady trickle of boilers breaking down and you are trying to repair the m using a diy site
Doing gaswork for others for any form of reward is illegal and nobody should be advising you and you should not be doing anyways.If you choose to do then do as the rest of us go and pass the relevant exams and join GASSAFE REGISTER
hi i have a baxi solo 30/pf could anyone tell me a straight replacement please, cause found out has hole in chamber
I wonder if he filled up the dangerous holes in the boiler!
hi , can anyone help . i have a glowrm spacesaver mk2, and would like to change it to a worcester any ideas please
He seems to be illegally fitting a lot of boilers!
