water luke warm in new shower
13 Sep 2011
Hertfordshire
my plumber quit but did most of work. however, the water in my shower is only luke warm and i only have it turned to hot all the way around all my other water in hot taps are red hot and pressure fine, it's just the shower. It was ok first time i used it but second time i used it i turned temp up and it went luke warm and is still like thst. note i have turned the temp the correct way. help!
Hi
Was the pipe work flushed out before the shower was attached it could be a blocked filter?
HTH
Not sure. If there is a block would it be in the shower valve that ii can get a plumber to look at?. If it was a block, wouldn't the water still be hot as I only have it turned to hot. Not sure if the shower has cold coming out when it's just turned all the way to hot.
How and why did the plumber "quit" ?
Was he not getting paid?
Tony
