Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
thanks for your help anyway because i now realise that the cold supply to the bathroom tap is actually mains fed and so asking about the taps pressure difference was not getting the answer to my real question.
what i was trying to establish is why the pressure available at the shower pump is much greater for the cold supply than it is for the hot supply.
the cold to the pump is fed from the cold tank which also feeds the cylinder so since both the cold supply to the pump and the hot supply to the pump have the same effective head, why is there much greater volume of cold water to the pump than hot water? the taps question was red herring!
there is a valve between the pump and the shower head in each line but if i close the cold and ensure that the pump is only pumping hot the head of water does not seem sufficient to feed the pump properly. is it likley there might be a blockage in the supply to the cylinder or out of the cylinder to the pump or is the case that the extra piping and work the head of water must do through the cylinder causes a pressure drop?
COuld be sucking air down the vent. Try holding a tumbler of water under the end of the vent pipe (over the big tank).
How have you plumbed the hot feed to the pump?
And make sure the hot isn't over 60º - cavitation.
the system has been incoreectly fitted (hot supply to pump teed off the horizontal outlet pipe on top of cylinder) but it did used to work. there has always been a difference in hot and cold supply to the pump even when each was tested individualyand the system worked
the question is should the pressure available from the hot supply to the pump and the cold supply to the pump be equal or should the additional work the head of water has to do to force water thorugh the cylinder cause a difference in the pressure avaliable at the pump between hot and cold
