WC Pan connector for 95mm soil pipe
5 May 2021
Hi all,
Trying to install new WC pan to cast iron soil pipe with 95mm internal width.
I can’t find any connectors for this. I only see products for 110mm, and 90mm outlets.
What’s the correct product to use?
The fins are usually what makes the seal and if you read the instructions or sometimes the website it will tell you the measurements, which some will seal 95mm, if you’re sure that’s the diameter. I’ve fitted plenty of wc pans to cast iron without a problem, usually opting for the 3.5” as above or an extension piece of the same diameter.
Ok thanks, checking out tech drawings, looks like one suitable product could be macalpime WC-F18R. So I’ll give that one a go
