Still planning the rewire!!!
I want to use a weatherproof box at the junction where "indoor" wiring meets "outdoor" wiring.
I'm going to be putting in some outdoor lights and a couple of pond pumps. What I am planning on doing is using a grid switch by the back door to control the various features.
From the grid switch, I was planning to run singles down and through the wall into the back of a weatherproof box. Inside the box, these singles would connect to the exterior cables.
That way I can wire the switches etc. once on the indoors, and as needs change in the garden I can assign (pre-wired) spare switches accordlingly. All accessories will be fused accordingly, on a second grid directly below the first, accessible but concealed within a cupboard.
If this is all acceptable, then I won't have to wire thicker, less flexible outdoor cables within a grid.
Questions:
1) Is the weatherproof box approach right, or is there a more elegant solution that still allows for future flexibility?
2) Are SWA and Hi-Tuf the only cables suitable for outdoor fixed wiring? SWA seems like overkill for supplying a low-energy PIR light, where it's going to be visible on the wall so not prone to digging etc! Plus terminating would be an issue...
3) When joining the "indoor" wiring to the "outdoor" wiring inside the moulded box, should I be using choc-blocks, or is there a more satisfactory way of doing it? Bearing in mind I want the joint to remain accessible and workable so I can reassign switches in future.
(BCO will be notified before I start work)
Questions:
