I went to put t.r.vs on a neighbours rads and in the loft i noticed the f and e tank sitting on a sheet of what looks like aluminium over the top of the c.w.s.t. Both tanks lids were missing and insulation was breaking off into the large tank. the cold feed pipes connection to the f and e tank had a white like powdery substance over the nut like it was corroded in some way on the outside of the tank. there was also a slight leak at this joint.
Should the f and e tank be on top resting on a sheet of steel on the lips of the cold water tank, cos a hunch tells me it shouldnt,and whats the best way to fix the leak, p.t.f.e tape as i cant use an oil based sealer? any help much appreciated
