Hi all
Long winded question so bare with me.
we are currently in the process of building an extension and basement conversion. We are installing wet underfloor heating in the new rear extension and part of the basement.
Now I know when installing Correctly to Combi boiler this will need 2 zone valves and wiring centre etc...
However ! I am Temporarily Going to connect my ufh Manifold to my current radiator circuit By tee-ing off my main flow and return. Now I know this will mean that the ufh will come on and the same time as my radiators which is not ideal. However my screed is booked in and I need the system up and running and pressure tested before screed goes down next week.
How would I get power to my UFH pump ? I want to hard wire it into the boiler so that when command is sent from my radiator thermostat the ufh comes on as well .
Is this possible?
I know it’s not ideal and not the correct way to efficiently install ufh however I will pay for a professional to change it over to zone valves on separate thermostats After my screed is laid and my ufh has been tested.
hope someone can help!
thanks
Is this possible?
thanks
