What Airless Sprayer to use with Peelaway1?
13 Jul 2010
London
Hello,
I'm looking to hire an airless sprayer to use Peelaway1 with and wondered if anybody here had any advice/recommendations. Peelaway is a paintstripper poultice that can be mixed with 20% water for use with an airless system but I'm not sure if I need a particular spec machine to deal with Peelaway. Would this one from HSS work for instance?
http://www.hss.com/g/61421/Portable-Airless-Spray.html
Cheers
JD
It's not a small job as I'm removing all of the paint from the front of my house. thanks anyway.
Better off with a roller than thinning it down and spraying all over the next doors car.
That's crossed my mind Joe 90. Have you used this paint stripper with a roller before? I was trying to avoid the mess you get when troweling it on.
Just a word to the wise, I spent 8 years as a manager for one of the largest ailess paint spray manufacturers in the world.
Spraying a paint stripper is a definate no no.
reason:
Yest the product WILL migrate to places where you dont want it, nextdoors conservatory roof, car, fence, plants and even pets because you are going to be atomising a product thats sole purpose is to destroy a coating at a micro level.
You and those around you will be breathing that in, it will be as a micro vapour, it will imediately start to work on the respitory system, if you are protected by the correct type of breathing aperatus then it will also be permiating into your clother to your skin. The people around you will also have this product in the air they are breathing and because its water bourn it will travel further that say an oil or solvent base.
If you are to roll this product then you still need to go OTT with the personal protection.
Seek the manufactures advise and stick with it as that way you are covered.
active85, I've decided against the airless system are going old school with a spatula.
