What connector do I need? Mains to cistern
5 Dec 2012
Hi all
I am putting in a new toilet. I need to connect a hose from the mains (isolation valve - see image) to the plastic thread on the cistern.
On my CURRENT toilet, there is a copper 90 degree pipe that goes into the side of the toilet through a hole, to which the washer hose connects.
I need to connect directly from the mains (isolation valve - see image) to the cistern plastic thread.
What hose do I need? I think I need this:
http://www.toolstation.com/shop/Plu...tors/Flexible Tap Connector/d20/sd2807/p76206
... but the only issue is that I need some form of copper pipe coming from the isolation valve, to which I need to connect the hose to.
Many thanks
Yes. You can use the pipe that was connected to isolation valve and cut a bit off and refix back onto isolation valve and use flexible tap connector to connect to cistern.
Dan.
