What is this in my ceiling?
25 Feb 2019
So we had a leak from the upstairs bathroom that's ended with a big hole in our kitchen ceiling. Inside the hole there's some weird lining.
It looks as if at some point there was a fire and one of the joists has been scorched and this has been used to wrap the joist, does this sound right? I don't want to remove it and it ending up being something more important...
More likely a bit of polythene was left under the bath rather than fixing a leak.
Looks a lot like the ESWA ceiling heating in my parents house, which was built in the early 80's.....
Ludicrous idea , heating ceilings, worked in flats where it was installed, tenants all complained of poor heating , though ceiling were nice and warm .
Hmmm. I wonder why? Could it be something to do with heat rising, perchance? I know that you can heat downwards by using convection and radiation n, but I can't help thinking that you'd need to use a lot of electricity to do this. Also, when this stuff was in use weren't they using asbestos as insulation? If so be careful how you handle any insulation
That "heating" was used - as said- in the 80's . We had a site ( Housing Association) that I maintained . No one used it, I used to take the fuses out for the tenants. That and on peak " radiators" were fitted . Just to conform to a Gov. directive I guess . Meanwhile all the good solid Council houses were being given away. Then mid 80's a programme from the Gov. Called Domestic Energy Notes 3 made things slightly better with night storage heaters. Between then and now, proper windows, gas heating, combi's were all fitted. ( at least on 1 estate I worked on , near where I live). Good times to be a Social Housing tenant now IMHO.
