What mortar mix for a fireplace
7 Mar 2013
Dorset
Replacing our fireplace with a Victorian cast iron type. The front hearth will be a granite slab but not under the fire grate. This will be cemented, but what mortar mix should I be using?
Richard
Just a sharp or building sand and cement mix, it’s not directly in contact with the fire and sits below it assuming you’re having the usual fire insert and ash pan
Just under 6-1 with a splash of ad mix. Would not go under 5-1.
Will give a bit and plenty strong enough and keep sand colour. 4-1 will be gray
