hi
built a gazebo/shed and now the warmer weathers coming, i want to spend a bit of time protecting it properly.
its been built with the weatherproof beams/decking/shiplap (cant remember the name but it turns it a bit green for starters) but not sure how to protect it further.
the roof is travisperkins 'external' plywood https://www.travisperkins.co.uk/Plywood-Hardwood-Throughout-12mm-x-2440mm-x-1220mm/p/767335#b
i thought it would be properly weatherproof but i started getting mould on it, and didnt realise i needed to protect it further, so now ive cleaned the mould as best i can, what would be the best solution for this ply?
i assume i wouldnt use the same stuff for all the wood, so what should i use for the shiplap, and the decking? ideally non-slip for the decking, but if the cost is too much ill just have normal stuff, just dont know whats the best option for the different woods.
id like it to be clear as i like the present colour.
thanks a lot
thanks a lot
