Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
What sort of flow rate do you want ?
Manufacturers give flow rate data for each pump.
Dont forget that more flow uses more water.
Is your cylinder big enough to supply the extra demand?
Is your header tank big enough to supply such a flow rate?
