Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I am due a new boiler and ultrasteel tank to be fitted. What size tank would you reccomend for a 4 bed detached 1 bath and en-suite and i have 3 children. i,ve had quotes for 210ltr and 120 ltr is the 120ltr going to be too small as the 210ltr quote was a lot dearer
I would have thought a 170 or 180 litre cylinder. it depends on the cylinder recovery time. If the 120 is a fast recovery cylinder then it should re-heat from cold in about 12 mins there giving you nearly constant hot water without having to store a lrge wasteful amount of hot water
installer said it would be a lot more money to put in a unistor.I dont want to be penny pinching but do you have an idea of difference between an ultrasteel and a unistor 155. Would it be worth the difference to put a unistor in
When using the Unistor via a VR65 the ecotec plus then controls the water temp. This is why the DHW temp knob is left on the front of a system/open vent ecotec plus boiler.
I cannot answer your question 100% positively but my understanding is that when unistor calls for heat the boiler will modulate to the appropriate level to heat the water quickly.
Depending on the timer used and assuming it is a Vaillant plug in one on the front of the boiler, then you also have the choice of an anti-legionnaire setting for the unistor, where every Wednesday morning the system will fire up to heat the unistor to 70C to prevent/kill off any bacteria present. Ideal for nursing homes etc and the health and safety requirements etc.
